Skybox f3 Alternative remotes/ adding a box
  • Armaghgeddon
    Hello all
    I was just wondering, is it possible to get a skybox f3 remote that is more responsive that then current remote?
    Also, I have just bought a 2nd box and I have a sky minidish, to add a new standalone box where I can watch different channels will I need to change the LNB to a double - will it effect the signal I am currently getting?
  • nibblitz
    • 1300
    Yea, you could try any of the earlier model Openbox Remotes (S9, S10, S11) Im sure they're all compatible, but poor remote response is not a common complaint, maybe you just have a duff remote or a badly seated IR receiver in your box..
    If you change your single LNB to a dual output LNB to feed 2 boxes it will not effect signal quality, but you might aswell fit a quad LNB, price difference is nothing and then you'll have spare outlets for potential future use...
    • kendo75
      • Jan 2013
      • 16
      Can confirm open box s11 remote works with skybox f3 ?4.95 delivered eBay
      • Armaghgeddon
        Oh, and is there any way to get the EPG working?
        • mezzyg
          • Apr 2010
          • 158
          Non way of getting EPG working on this box I'm afraid, the remote on open box x3 &x5 is a lot better then the skybox quicker response,
          I've also found using better batteries helps on the f3 remote
          Sent from my Nexus 4 using Tapatalk 2
          • ando
            • 30
            i ended up removing the piece of plastic at the front of the box where the channel numbers are
            cut a small hole in the plastic where the ir sensor is and placed it back in, remote now works without having to aim directly at the sensor, not particulary pretty but it works
            • mezzyg
              • Apr 2010
              • 158
              I've done that as well, it just clips off,
              • stevewild31
                • 81
                I replaced my F5 remote with a Logitec Harmony 525 (was using it on the TV anyway), Much better response and I don't have to sit right on top of the box for it to pick up the remote.
                No EPG but if you load the channel list sorted into Sly's numbers, then keep sly channel guide on my laptop (Channel Numbers then corrispond).
                • Ginge9570
                  • Feb 2013
                  • 16
                  SKYBOX F3
                  Ive tried adding a HDD to this box and also a Discq dish control but for some reason its settings are all LOCKED and you require a four digit pin this is not issued by the seller. Anyway of getting the pin from the RS232 or is it impossible. Regards.
                  • nibblitz
                    • 1300
                    Well, your seller is an absolute arse then if he wont tell you what its been locked down with, they dont leave the factory like that..
                    Try all the usual suspects, 0000, 1234, 1111, 6666, 8888 etc
                    The other way to unlock the box would be to flash it via rs232, which will probably also erase any custom setup & settings on it...
                    • Ginge9570
                      • Feb 2013
                      • 16
                      SKYBOX F3
                      Ive tried all them codes. going around in circles. Dont want to wipe it.. just want to be able to put channels i watch most in the order im used too. Like BBC 1 on 1 etc. cant move anything or add anything to the box. pain in the behind.
                      • nibblitz
                        • 1300
                        I would pressure your seller, with it locked down you cant use the box properly, its almost like a faulty box.... What are you going to do when channel frequencies change? And what if you wanted to get other satellites, the box is designed for that, but you cant because its locked down.. I wouldnt accept having a box in a locked out condition, nor should you...
                        • redondo5
                          • 277
                          that sound interesting, could you possibly upload pics?
                          • technics123
                            • Mar 2013
                            i use one of these and now i can point the remote anywhere in the room and it works fine on my skybox f5
                            it took 2 weeks for it to be delivered from china
                            i,m gona change the ir led to a higher power one in the remote and see if that makes things better also
                            but i will note that its not a problem with the remote that gives us all this trouble
                            its more to do with a problem with the ir senser in the f5 box , but i dont fancy cutting holes in the front of the box to fix it
                            Infrared Remote Control Receiver Emitter USB Adapter IR Extender Repeater EA | eBay
                            • Glee30
                              • May 2013
                              technics...
                              wee query on how that works..
                              USB into the usb slot front of F3 box, sensor somewhere in the room. anything else?
                              My skybox f3 remote is shocking, works - doesn't work - works - doesn't work - doesn't work...
                              battries changed again & again.. spanking nw Duracells & Energisers... going loopy.. contacted seller as box only 4 months old..
                              checked remote with camera on phone and the infrared ain't firing out..
