F3 is solid and most common, but I prefer the remote and interface of the open box x3
Hey Mezzyg, thought i'd jump on the op's post
I was just looking at the X3
A lot of sites are now stocking the X5 as 'replacement to X3'. Would you recommend I still look to get an X3 for a simple additional box or the X5?
And would you suggest the X3/5 over the F3 in my case? I saw some F3's on Fleabay for ?45 which isn't much cheaper that the X options, so I guess i'm just looking for opinions on the best 'second box' option from peoples experience.
I have a BM downstairs so haven't seen anything of these openbox types.
If you can afford ?139 go for a maxdigital p1000 as its a real enigma 2 box with real support and a full 7 day epg. I know its a fair bit more and takes some learning to set up but its a superb box in comparison.
I have had a vu duo and a few of the cheap skybox's and the p1000 is almost as good as the vu in my opinion.
I thought I could get used to a basic box but found them a bit hit and miss.
I personally would go for either F3 or F5 (virtually the same f5 has scart, rear usb and external psu). I had the openbox x5 for a while but at the minute it has too many really annoying niggles and is harder to set up.
