record
  • carpy47
    • Feb 2013
    record
    hi
    I have skybox f5 anyone know if you can record while watching a different channel, if you can how do you do it.
    I think the answer is no I cant, if that is the case why have I 2 lnb inputs, 1 I think says loop.
    regards
  • gracieboo
    • Dec 2010
    • 368
    No you can't one is for lnb input other is loop out its used to connect another box with a run of cable.
    • carpy47
      • Feb 2013
      ok thanks for the help.
      regards
      • Bigpineguy
        • Feb 2013
        as stated , loop out is for running another box ....but not recommended for many reasons....
        Best bet would be to add another stb , and use one for watching and the other for recording....Many ppl have/use more than one box ....
        BPG~
        • carpy47
          • Feb 2013
          hi
          is it possible I get a dual tuner receiver ?
          regards
          • jagandeep
            • Dec 2012
            • 5
            BPG~
            Why is it not recommended?
            • nibblitz
              • 1300
              The signal from the Loop out is cut when the Openbox/Skybox is powered on, any box connected via the Loop out will lose its signal until the Skybox/Openbox is powered down again...
              • nibblitz
                • 1300
                Originally posted by carpy47
                hi
                regards
                Not a cheap Skybox or Openbox... There are other makes of receivers with dual tuners, but they cost considerably more...
