Leaving skybox on or power off to save bandwidth?
  • GoonstaVIP
    • Feb 2013
    • 4
    Just wondering if people power off their sat box when not using for long periods to save bandwidth?
    If the both is left on 24/7 must use a bit of data?
  • cactikid
    • 12017
    all boxes and pc are left in standby,not powered off,only thing i power off is lappy.
    • nibblitz
      • 1300
      In standby its not going to use any bandwidth, its shut down...
      Its best practice not to leave your box on when not watching, its going to use hardly any of your bandwidth but its making your server have to serve unnecessarily, and if every other user did the same then it all becomes a much more glitchtastic experience for those trying to watch...
      • ramjet
        • 2995
        not all boxes are off in standby, some only switch the tuner off and the rest is still on and using bandwidth so are not shutdown (maybe not the skybox however)
        but they use little or no bandwidth anyway, the important thing is they are wasting power, so its about saving power, not bandwidth, and should be powered off when not in use overnight
        • sb18180
          • Sep 2012
          • 355
          skybox f5 is still connected on standby if you are using lan cable but if you are using wifi its disconnected.
          • nibblitz
            • 1300
            No its not. When you put the box on Standby its Linux kernel shuts down... It cant be connected to anything as the OS is not loaded up and running... Why do you think it has to go through a boot up sequence when you turn it back on from Standby...
            • sb18180
              • Sep 2012
              • 355
              when you switch off with lan connected it shows disconnected on the router when in standby its showing still connected on the router also shows the same on my server info but with no channel chosen so its still talks to the server in standby.
              • nibblitz
                • 1300
                Oh my... Of course your server shows no channel chosen, because your box is not communicating, its shutdown... When your box is on standby (shutdown) your router and server is only seeing the NIC, not the box, the box cannot communicate, its OS is shutdown, there is no communication, its not talking, no data will transfer because it cant, so no bandwith will be used when your box is in standby....
                • DW190
                  • May 2012
                  • 1263
                  I would tend to agree.
                  Simple test for any doubters is to log into your router and check connected devices.
                  • cactikid
                    • 12017
                    same as pc in standby it always puts up the message now connected
                    • sb18180
                      • Sep 2012
                      • 355
                      right not connected to router so no data used in standby
                      • happy_highlander
                        • 3535
                        Re: Leaving skybox on or power off to save bandwidth?
                        If You are worried why not just put your box on a fta channel and no request will be sent to your server. Then put it on standby or if it really bothers you remove the ethernet cable
