Skybox F5 Mismatch OFF!!
  • tayta
    • Oct 2012
    • 26
    Guys
    I've downloaded the latest F5 firmware from the cc site, and via USB I get a file mismatch error.
    So I looked into it and read that it can be when a firmware has been loaded that does not allow for USB updating etc, and you should use serial.
    I downloaded and tried the LAN update first. I connected fine, it uploaded the fw...then the same, file mismatch error.
    I have now downloaded the RS232 tools and am trying to upload the new fw but it wont work for me. All I ever get from the tool is "Synchronising STBs please reset target!".
    I've reset and rebooted more than once and it goes no further. When I disconnect the cable after waiting way too long...the box reboots and carries on as normal.
    Can anyone pleeeeeease suggest what i'm doing wrong and how I can update the FW on this thing?
    Cheers
  • rrsmith21
    • Mar 2013
    Hi Tayta Skybox F5
    I dont know if this is any help but I had same issue. I downloaded latest firmware update from cc site and also from yojiatech but could not flash, always got (file mismatch error) no matter what I tried. I then found this site hddvbsw.c*m which had a different and older firmware upgrade 14/1/2013 also with a different string or code than the other two suppliers, but this flashed my box okay.
    I really dont know why but suspect my box may be a clone?
    • LeonRead
      • Jul 2012
      • 23
      Originally posted by rrsmith21
      Hi Tayta Skybox F5
      I am sure your box is CLONE .
      • sb18180
        • Sep 2012
        • 355
        clone/faulty box if you update via rs232 it will put it into bootloop. the only firmware that will work on it is the one it come with SEND IT BACK
        • rrsmith21
          • Mar 2013
          I dont have any issues with my maybe cloned F5 box working okay, only thing is that I cannot install original firmware.
          Last night I down loaded and installed latest firmware SKYBOX F5 _3601HD_CMT_130327.abs (8.4.2013) from HDDVBSW.C** and again upgraded okay, fixed Utube and channel scrambled etc.
          • tayta
            • Oct 2012
            • 26
            Yeah it turned out to be. I've used the other updated firmware for my box from this........ originally posted .......
            Just in case anyone was still struggling with this.
              Read the Forum Rules again Please: http://www.digital-kaos.co.uk/forums...rules-2/#post2: Do not post links to other forums with similar content
              • Debiz77
                • Feb 2013
                thank you sir
