hi guys just after some advice,got skybox f3 which was working fine,all of a sudden it shows no signal,ive updated firmware and still have same problem,i did a rescan but it picked up nothing,i know its not the feed as my sly box works fine and so does my openbox,so ive come to the conclusion that the tuner in the box is at fault,does this sound feasible? just after conformation that the box is indeed at fault
Skybox f3 signal
Tuners on S10 clones had poor fit and slipped from the sockets, could be seen through the vents. If your happy to open the box to make sure the tuner is pushed home on the main board. You will need to loosen the tuner screws to do it.hi guys just after some advice,got skybox f3 which was working fine,all of a sudden it shows no signal,ive updated firmware and still have same problem,i did a rescan but it picked up nothing,i know its not the feed as my sly box works fine and so does my openbox,so ive come to the conclusion that the tuner in the box is at fault,does this sound feasible? just after conformation that the box is indeed at fault
