Skybox F5 and Virgin Wi-Fi
  • nokmond
    • Jan 2013
    • 27
    Hi, has anyone else had problems connecting to Wi-Fi on virgin?
    I've got a super hub which comes up on the Skybox as wpa2 and it will not connect. It connects fine to my tplink access point which just says $wpa.
  • batsbats
    • Feb 2013
    • 14
    f5 wifi
    hi i am on talktalk and can not connect f5 to wifi my skybox f3 is connected wifi but i have tried everythik to connect f5 other people say they are on wifi with it
    • nokmond
      • Jan 2013
      • 27
      After much searching of this excellent forum I finally found something that worked! Here it's what I followed -
      Set ur SSid with small or capital letter (all)
      eg : abc or ABC
      set ur auth to wpapsk or wpa2psk (AES)
      set ur password with 5 or 13 chars.
      eg:
      -abc12
      -ABC12
      -abcdefgh12345
      -ABCDEFGH12345
      • batsbats
        • Feb 2013
        • 14
        WIFI
        just tried that still didint work ad to set me f3 back up that worked straight away am puzzled
        • nokmond
          • Jan 2013
          • 27
          My problems were the virgin super hub but if you trawl thru the forum you'll probably find a talk talk fix. Good luck
