samsung tv no signal with f3
  • damo2010
    • Oct 2010
    • 125
    hello all i av a skybox f3 but will not connected to a samsung tv using hdmi it says no signal or unsopported format can any one help me plse
  • skywatch
    • Feb 2013
    • 45
    tv
    try the f3 on another tv to start ///also have you got anything to work on hdmi 1 or 2 etc ////read your tv instructions ..have you got to turn anything on or change settings on tv to get it to pic the f3box or any other device through your hdmi cables ///
    • nibblitz
      • 1300
      Press the Vformat button on the remote control repeatedly (with pauses in between each press) until you get a compatible output format displaying correctly on your TV...
      • damo2010
        • Oct 2010
        • 125
        cheers will try that when home
        • DW190
          • May 2012
          • 1263
          Another I found with an old Samsung was that if the settings on the HD box are set to RGB old Sammy doesnt recognise.
          • anno 1366
            • Apr 2010
            • 272
            i had similar proplem with sanyo tv .it did work with red,yellow and white leads ,but not hd
