Skybox F3 multi-satellite settings - help needed
  • primitiverising
    • Jul 2012
    • 7
    Hi guys,
    My subscription recently expired & have done research to pay for & set up new subscription.
    One key thing though: my original subscription (& box settings) did a search of assorted satellite signals (not just Sky UK), & loaded other channels - very handy in the case of a channel like ATR as signal is weak on Sky UK, but was able to get this channel via one of other satellite feeds.
    To cut long story short, I added firmware as wanted more organised channel list etc, but this is now set up only with Sky UK, & in menu, when I go to multi sat search, only Sky UK shows up, none of the others.
    Is there any way I can retrieve the other satellite settings so it searches those as well?
    Many thanks.
  • digicon
    • 8261
    You could try this one not too sure on its age probably a couple of months old but it does have Multi Satellites.
    • nibblitz
      • May 2010
      • 1300
      Manually add the other satellites you want into the satellite list then blind scan them...
      • primitiverising
        • Jul 2012
        • 7
        Thanks guys - will give this a go
        • primitiverising
          • Jul 2012
          • 7
          Apologies if this is a really stupid question but I'm a newbie at all this: once that channel list file is unzipped I am left with TP_PROG.dbs but it is only 1Mb in size - will this have the required data in it to load via USB to Skybox, or have I gone wrong with the unzipping?
          • digicon
            • 8261
            Once unzipped put onto a USB stick and upload to the F3
            • programmer10
              • Feb 2013
              Cannot open it!
              When I unzipped it, it extracted a file "Multi Sat TP_PROG" without an extension. So I manually typed the extension to become "Multi Sat TP_PROG.dbs". But when I tried to uploaded to the receiver, it did not work. It showed an error "File mismatch". I even tried to open it using "SetEditHD100" it could not open it either! Any help please!
              • mohammed107
                • Feb 2013
                Hi ive recently bought the skybox f3 it was working fine for fw days
                Now everytym I watch it it keeps flickering allthe time very frustrating
                Please can sum1 help!!
                • sb18180
                  • Sep 2012
                  • 355
                  that sounds like you have a crappy server
                  • maaurelio
                    • Feb 2013
                    io ho il dec modello openbox s10 mi manca la lista con i nuovi canali di sky 13?
                    • digicon
                      • 8261
                      Originally posted by programmer10
                      I just re-downloaded this file extracted it which produced a folder called Multi Sat TP_PROG inside that folder is another folder called TP_PROG and inside there is the actual file itself TP_PROG.dbs
                      Regards
                      • Jeff1234
                        • Mar 2013
                        is this an european list ?
                        • digicon
                          • 8261
                          The Multi Sat in the title may just give you a clue yes it is
                          • mars2015
                            • Mar 2013
                            Hi bought the skybox f3 fw days ago and need some help ,
                            I do not how to set up because my satellite is motorised ,
                            Before I have a old dream box multimedia
                            Please can some one help!
                            • digicon
                              • 8261
                              Hi mars2015,
                              welcome to the forum everything you need is in this guide here: http://www.digital-kaos.co.uk/forums...-guide-257009/ although it saysopen box it also applies to the Skybox as well
                              Good Luck
