Skybox F3 no signal problem
  • speighty
    • May 2012
    • 6
    Hi guys, seem to be having a problem with my f3, purchased it back in november and its been ok up untill a few week ago, noticed on certain channels i get no signal, for example, i can get sky sports hd 3 but the rest dont work, same with sky1, sky 3d.
    I can get most of the movie channels apart from one or two, i am using ajs channel list, if i search for channels some that had no signal using ajs list do work but the scan does not find all the channels.
    I am thinking of purchasing a vu+ solo but dont want to get it if i have the same problem.
    I have tried factory settings on the f3, different images but all produce the same problem.
    Any advice would be great.
  • skywatch
    • Feb 2013
    • 45
    channel fault
    hi mate have you checked your sat dish is aligned rite ...also check your cable for connection probs if ya can test ya box off another sat feed ie friendas house ,,,,sounds like that fault on dish alignment or cable check your frequency %%on sats
    on youe bad channels
    • stikz1888
      • Dec 2012
      Please someone help i have a skybox f3 and everything was working fine and i was using aj's channel list and someone done a blind scan and then no chanells were showing and now i only see no signal please help also i have checked with a real skybox and the fta channels are coming up fine
      just reinstalled firmware too and thats not helped have checked soish with real skybox and working fine so dish is fine its since a scan was done halfway thru a blindscan the box crashed and then it was turned off before search had fi8nished and this has let to this first being scrambled and the no signal at all even on fta channels
      • souldude
        • Jun 2011
        • 37
        Hi
        Just load the channel list back up from aj's and you should get your channels back.
        • souldude
          • Jun 2011
          • 37
          Hi
          How long have you had your dish up?
          If its an old dish the LNB may be your problem as i have had people ask me this and when i have put up a new LNB all the channels work much better.
          The vu+ solo boxes are a lot better but until you cure the lost of channels/signal the solo may be the same.
