skybox wont power off
  • discusfish
    • Feb 2013
    hi all any ideas why my skybox f5 wont power off
    press the power button the box just reboots.
  • nibblitz
    • 1300
    Perhaps your remote is spewing out IR longer than it should be, sticky button maybe, so when you press the button your box goes off, but maybe the remote is still sending IR out so the box comes straight back on again..... Have a look at the IR beam from your remote when you press the standby button (look at it through a digital/phone camera) see if it goes on for longer than it should be...
    • Webhopper
      • Feb 2013
      hy,nearly same problem - skybox F5 reboots always to 100 after settings update ! is it possible to flash new Image ?
      • Webhopper
        • Feb 2013
        Bootloader Skybox F5 with RS323 repaired - sorry for German instructions.Hope i can help someone because i need help,too.i need settings with favourits list for Astra 19,2 E.So my report over broken Bootloader:
        Anleitung :Skybox F5 HD PVR aus Ladeschleife retten
        ! Falsche seetings aus Netz umgewandelt - Box Ladeschleife ( kein USB oder Lan verf?gbar ) , gerettet mit :
        STB-EROM UPgrade 2.0.0.c ?ber Nullmodemkabel , Com 1 , 115200 Bits , Operation Mode : Upgrade
        File : Image.abs (Backupdatei oder Original aus Netz umbenannt ), Include Bootloader : ja
        Box Ok
        Thanks and good Luck
