Cant install any firmware on openbox
  • Frogger
    • Oct 2012
    • 422
    This is the box I am/was using [ame=http://www.amazon.co.uk/gp/product/B0089NUYQU/ref=oh_details_o06_s00_i00?ie=UTF8&psc=1]Openbox[/ame]
    I was using the USB with a very long USB lead to watch some downloaded films on the PVR section of the box.
    My mate came in and tripped over it and snapped/broke the USB connection right off the front of the box.
    Problem is, I had just done a factory reset and was going to install new firmware (No firmware for $$$ channels on it now)
    I opened the box thinking it was easy fixed and used a heat gun to remove the offending pins/wires from the OSD pcb, but they came of the board leaving NO soldering points left.
    Now I can get a USB to solder to the OSD pcb and cant put firmware on the box to watch $$$ channels.
    Any ideas as to what I should do? Can I install firmware vie ethernet?
    Or is it just a Null Cable I must use?
    Please help as ive null-no channels now but I knw the box is fine.....
    HELLLLLLPPPPPPPP
    I took some pics if anyone needs them to assist me here.........
    Thanks in advance!!
  • slugworth
    • Nov 2011
    • 1064
    the mate owes you a new receiver
    • Frogger
      • Oct 2012
      • 422
      Here are the pics as requested by a fellow DKer in PM.
      The solder points are f000ked mate. The heat gun was on red hot ffs. My schoolboy error.
      Raging at myself...............
      The 1st pic is from behid the PCB from the OSD
      • Frogger
        • Oct 2012
        • 422
        But can I not install fw through ethernet or null?
        • andye26
          • Mar 2010
          • 131
          Traces are damaged but looks repairable
          If you can get the PCB or unit to me I should be able to fix it.
          Contact details via PM
          Regards
          Andy
          • Maxster666
            • Mar 2013
            Hi, could you please send me a link to the firmware download,
            i,m new to this and can't find it
            • slugworth
              • Nov 2011
              • 1064
              car without tires
              It's like a car without tires,if you can't record with it.
              • Frogger
                • Oct 2012
                • 422
                I dont think your getting me here.
                The PCB is damaged. But it is working fine, except for the USB part. The time and channel numbers show up. The buttons and IR receiver work.
                So, can I or cant I install the firmware and ccam.cfg through Rs232 or something similar?
                • tonynw
                  • Nov 2011
                  • 147
                  you tried putting in the information you need via the remote control ??
                  tonynw.
                  • sb18180
                    • Sep 2012
                    • 355
                    you can install firmware via rs232 you may be able to install it via the lan tool as well if it works with openbox as stated above Cccam cfg by the remote manually
