Upgrading channel list help
  • zippo
    • 9
    When I try to upgrade channel list by usb it says upgrade finished. press "Info" key for result. When I press the info key it says TP_PROG.DBS (Sat,TP,Prog)......file not found
    Anyone know how to fix this?
    It's AJ'S channel list that I'm using
  • mrnathan92
    • Mar 2013
    Is the file on the root of the USB?
    • zippo
      • 9
      Yeah the file is on the root of the usb. I'm going try another usb tomorrow.
      • sfsecure
        • Mar 2013
        Same happened me yesterday. If you open up the unzipped folder and save the contents on another USB stick and put that in it will work. It worked for me
        • walkaton
          • May 2011
          • 67
          select Misc file did you
