sly f3box
  • leeboybcfc23
    • Mar 2013
    • 4
    sly f3box
    hi there i have brought a dongle for my sly 3 box but when i go to ativate the wifi dont do nothing on box also how do i get into to see my lines etc im a newbie cheers lee
  • nibblitz
    • May 2010
    • 1300
    Did you buy the correct wifi dongle? Or did you buy any old dongle?
    • leeboybcfc23
      • Mar 2013
      • 4
      i brought the right one little black one of amazon just dont do nothing when i put it in very confused go to activate wifi but nothing just says nothing i put it into the usb thing on front of slybox
      • Nutty34
        • Feb 2013
        • 130
        sly f3box
        Mate wifi on the F3 really is not good, even if you manage to get it working it is probable you will get constant glitching/scrambled messages. If you can not run via network cable (RJ45) then do yourself a favour and invest in a set of home plugs.
        Posted using Tapatalk for IPad.
        • leeboybcfc23
          • Mar 2013
          • 4
          ok will leave it then as why change somrthing that aint broken but how do i get in to see my sea loins etc as i dnt seem to be to ascess them and i brought a 12 month goft and worried if it dnt last hw i can put my own in cheers lee
          • mtv1
            The Stig PT
            • 4413
            m8
            its in network cccam manage config files
            but its hidden and there is no way to see iy contact your provider
            • Nutty34
              • Feb 2013
              • 130
              sly f3box
              Originally posted by mtv1
              m8
              If this is an F3 there is a way to see it mate
              Go to Network Local Setting (network setting is a sub menu) when you press 6666 this opens the camds setup,you then have to open camds setup to find MGCamd plug setup or Cccam if you have a cline.
              • leeboybcfc23
                • Mar 2013
                • 4
                cheers nutty u r a star pal many thanks for the help as i am a newwbie
                • mtv1
                  The Stig PT
                  • 4413
                  sorry m8 but you will not see the details are what i meant
                  not the hidden menu
                  thread carefully cs talk is against the
                  • Nutty34
                    • Feb 2013
                    • 130
                    sly f3box
                    Again you can if you use dump to USB then open with notepad.
                    • mtv1
                      The Stig PT
                      • 4413
                      ok i give up
                      but u never said that in your previous post
                      nn maca
                      • Nutty34
                        • Feb 2013
                        • 130
                        sly f3box
                        ok i give up
                        nn maca
                        No mate, you are correct, I didn't
                        • walkaton
                          • May 2011
                          • 67
                          all that leeboy wants to do can be done using F3x3lantool.just set box ip and login. you will see local and box files . I transfered all files from box to local(f3x3lantool folder). edit what you want in local and transfer back to box. cccam can be viewed, edited and save all on this tool if file is not hidden.
