Skybox F3 motor control
  • gerrywac
    • Mar 2013
    • 21
    Hi All, a little help if you can please
    I have bought an F3 to replace a blown reciver on my motorised dish and I am having problems wih the motor control
    Are there any known problems with compatibility between the F3 and a Technomate 2300 motor in Diseqc 1.2 or USALS
    The motor works using its own push buttons and from the box using the right/left handset control but will not position itself automatically.
    I borrowed a cheap Ross box and that doesn't work properly either so I am beginning to thik that whatever took out my old box has fried the motor electronis as well
    Gerry
  • nibblitz
    • 1300
    No it should work fine with Skybox if your dish is good and was installed properly.. You have put your correct Log&Lat into the box settings, and enabled USALS for all satellites, havnt you?
    • gerrywac
      • Mar 2013
      • 21
      I set the dish up a couple of years ago and it was fine until my old box went.
      The skybox is set up correctly for Lat/Long and USALS on for all the sats
      I think the motor must be toast
      • willlagreen
        • Aug 2013
        • 12
        I too am having problems. I have the F3s with a 1m dish on a STAB 120H-H motor. Iv'e tried USALS and Diseq1.2 but even though I get a message on screen saying "MOVING DISH" the dish isn't moving at all. The cable in the house is going into the LNB connector on the back of the Skybox, not LOOP. Am I missing settings in DISeQ or 1.1 ? Or is my motor goosed?
        • shaunfree
          • 358
          hi,gerrywac +willagreen try to manually move motor via east and west buttons on the actual motor to (0) position then press the reset button (small hole under actual motor) then turn your box off and disconnect sat cable, then put back in an power box up,i had same prob with motor not moving told to try this method and worked 4 me,hope it works 4 you cheers
            Thats OK for the general rule of thumb diseqc motors but the OP with the STAB cannot as they have no external buttons or even active lights
            • shaunfree
              • 358
              hi,and thanks digicon,me been a newby to the motorised sat world, did not no there was a difference between diseqc+STAB op,looks like i have still got plenty to learn,thanks for the info mate,
                No problem the STAB brand and its clones are still Diseqc motors but have no buttons such as the dark Motor,TM2300/2600 East - West so to speak
