Skybox Channel Moving
  • Smurf786
    • Sep 2009
    • 195
    Does anyone know how to move channels around within the favourites on a skybox f3?
    I have a friend that has scanned some channels in and added them to favourites but they appear at the back or bottom of the list. Want to move them back up.
    Is there any software like dreamboxedit to edit tp_progs.dbs channel files to move them about aswell?
    Many Thanks
    Smurf
  • seangraves
    • Sep 2012
    • 275
    channell moving
    Is there any software like dreamboxedit to edit tp_progs.dbs channel files to move them about aswell? {{{{hi mate just go into your menu and use your channel edit etc to move channel were you want it ie go onto your channel that you want to move then press menu go to channel edit etc it tell you with colour of buttons which button to use to move channel up the list then once moved it press ok exit it should say saving data then thats job done
    Many Thanks
    Smurf
    • Smurf786
      • Sep 2009
      • 195
      Thanks for the reply, will try it and report back. I did try moving channels in channel edit but couldn't do it in the favourites. Will try again.
      • walkaton
        • May 2011
        • 67
        Many Thanks
        Smurf
        alieditor will do what you want. rename file from dbs to abs and make sure you change it back to load in box. Using the dbs file in the lan_mm tool make it easy to send to box after editing
