skybox f3 pin locked
  • sirgodha123
    • Mar 2013
    Originally posted by mittonsimon
    3313 = passsword
    Hi, I have skybox f3 i cant access menu i try all number 0000, 6666, 3313 etc.. but no luck i try with serial cable cant update firmware any suggestion apprecaited
  • sb18180
    • Sep 2012
    • 355
    if you brought it with gift already on its probs been changed by supplier to keep novice fingers out!
    • samsid
      • Mar 2013
      • 60
      Try 3133 ,8888. as said above it's mostlikely been changed by seller. adding firmware via rs232 method is only way, just keep trying
      • seangraves
        • Sep 2012
        • 275
        hi mate if your provider as set it up can i ask why u want to access it if its running ok ?.....or ave you changed the code and forgot it need more info
