Noob Question - Internet speed
  • jammikkar
    • Mar 2013
    • 7
    Hi There,
    I have purchased a Skybox F5 with Wifi dongle (awaiting for them to be delivered).
    As a nubile, I will have to find my way through this new venture but I hve the following question:
    I live out in the country and as such only have a 0.7mbit/s connection, is this going to cause me serious issues?
    J
  • Nutty34
    • Feb 2013
    • 130
    Personally mate I think the wifi adapter on the F5 will cause you more issues than your Internet speed.
    Posted using Tapatalk for IPad.
    • jammikkar
      • Mar 2013
      • 7
      OK, thanks, I can link via RJ45, but would prefer not to trail a cable round the house.
      • sb18180
        • Sep 2012
        • 355
        its either trail a cable or use homeplugs otherwise if you use wifi your picture will freeze like mad
        • Nutty34
          • Feb 2013
          • 130
          Mate if you do not want to trail cable around the house invest in a set of home plugs. The boxes work a lot better hard wired, the wifi on them is rubbish, works for some but not others.
          In terms of your speed, the F5 can actually be ran on 3G, getting the key data from your CS server is more important this is a very small amount of data,say in the region of 5 meg a day or so.
          Ping times and the route your ISP takes to your host is actually more important than raw speed.
          • jammikkar
            • Mar 2013
            • 7
            OK, will either cable or home plug it in. As far as the routing/ping speed... will have to wait and see.
            Next stop, looking for that elusive (and trusted) "internet data".. Google here I come!
            • DW190
              • May 2012
              • 1263
              If your quick they're going cheap here at the moment.
              Buy ON NETWORKS PL200-199UKS 200 Mbps Powerline Adapter Kit | Free Delivery | Currys
              • bbb_uk
                • 429
                Originally posted by jammikkar
                .... As far as the routing/ping speed... will have to wait and see.
                visit pingtest.net (making sure nothing else is using bb and rerun test again if you get a bad grading.
                • jammikkar
                  • Mar 2013
                  • 7
                  Just checked speed... Ping 60ms Jitter 7ms.
                  • DW190
                    • May 2012
                    • 1263
                    Mine on BT is
                    Ping 30ms Jitter 1ms
                    • jammikkar
                      • Mar 2013
                      • 7
                      Originally posted by DW190
                      Thanks, brought these with an ethernet hub. Works fine. Just got to enable the internet thingy.
