help with clone box
  • rod1977
    • Jul 2012
    help with clone box
    I had an s10 box which was bricked I used the rs232 lead to unbrick it and put clone friendly firmware on it the box comes on ok but it will not detect any channels I have tried different channel lists and different firmwares but still nothing I have tried blind scans but it will not detect anything any help would be appreciated
  • sb18180
    • Sep 2012
    • 355
    if you are getting no signal thats anything from dish to box and the bits between
    • Hadron
      • Nov 2012
      • 2102
      Is your antenna setup correct in the menu? (LNB freq. = Universal[9750 - 10600], DiSEqC = disable).
      • DW190
        • May 2012
        • 1263
        Quite a lot of clones were very poor quality and the tuner worked its way out of the motherboard so much so that they started putting rubber blocks built up on the tuners to hold them in.
        Remove the cover and make sure the tuner pins are all seated.
