channe llist
  • wastedspark1982
    • May 2012
    • 44
    channe llist
    Ive got a skybox f3 and wanna install A'J's channel list , ive fondthe file online do i just copy andpasteit to my usb stick?
    How do go about intalling it to my f3 box? im a newbie to this
  • DW190
    • May 2012
    • 1263
    Extract the file with winrar and copy to the root of the mem stick. In the menus look for upgrade by usb, change the top box to Misc then select and press ok to put a tick at the side of TP_prog.dbs then press the yellow button. When finished reboot box.
    • wastedspark1982
      • May 2012
      • 44
      I saved it to winrar then copied it to my memory stick but insure what 'root' means.
      I tried to open the file and it came up with a error msg but when i viewed it i had aload of words and symbols come up.
      do i have to remove the old channel list first?
      • DW190
        • May 2012
        • 1263
        You dont save it to winrar. Winrar is a programme to extract a compressed file.
        Save the file to your desktop and right click on it, select extract here. You shoud the see the TP prog file that you drag and drop to usb mem stick.
        • wastedspark1982
          • May 2012
          • 44
          Done how you said.
          Just double clicked on it and msg says the archive is in either unknown format or damaged? should it say that?
          • DW190
            • May 2012
            • 1263
            Done how you said.
            Why you no wissen? "Just double clicked on it"
            RIGHT CLICK ON IT, SELECT EXTRACT HERE
            Yes I am shouting so you will hear.
            • digicon
              • 8261
              Done how you said.
              Hi mate if the file is in .rar format then you can download 7zip which is a free program that can unzip .rar files for you.
              • wastedspark1982
                • May 2012
                • 44
                Ok done all you have said.
                do i have remove old channel list before i try and put new one on??
                • avd
                  • Feb 2013
                  • 20
                  I wiped my channels when i updated to ajs channel list. Im sure it tells you what to do in his sticky at top of forum.
                  • wastedspark1982
                    • May 2012
                    • 44
                    Ok thanks.
                    how do you go about channel updates does it work like rats bouquet?
                    • digicon
                      • 8261
                      Ok thanks.
                      It does not work like an auto updater i'm afraid you will have to keep an eye on AJ's thread for the Updates he does to his list which is kept pretty much up to date
                      • wastedspark1982
                        • May 2012
                        • 44
                        just updated it took 30 sec and worked a treat ,i dont know what i was flapping about
