Keep getting "SCRAMBLED"
  • boylan
    • Oct 2011
    • 128
    Hi i keep getting a scrambled message on HD channels is this to do with my signal i know its not my provider as i know others who use the same provider and its fine for them, thanks in advance for the help
  • termiantor
    • 400
    scrambled has nothing to do with signal mate are u running your box hard wired or wireless
    if your sure everything is ok your end contact your provider
    HAD THE PARTY LOL
    • sb18180
      • Sep 2012
      • 355
      it could be anything to do with internet side slow ping speed,router speed,wifi if using it down to the server.
      • singh1234
        • Aug 2009
        • 156
        Hi, I am getting the same problem here where getting scrambled
        • andy91
          • Aug 2010
          • 3583
          Wifi on these are crap use Ethernet.
          If the fta channels are ok its internet related either crap isp or server.
          Andy
          • boylan
            • Oct 2011
            • 128
            Hello all thanks for the replys I think it may be my router slowing the signal down, as my laptop is dropping signal too when connected, i use homeplugs so i can use ethernet
            • mark8393
              • 2305
              Are they plugged straight into socket? I know some font like going in extension leads
              • boylan
                • Oct 2011
                • 128
                Yes mate both plugged into the socket
                • sb18180
                  • Sep 2012
                  • 355
                  its not so much speed its a good ping to your server you need. try a test at pingtest.net it will give you an idea. also alot of people who are getting troubles are newbies. as you get more into it you will know the things to check and look out for and what causes issues and what does not.makes me laugh when people have the box 5mins get glitching or cannot connect to a server and blame one of two things the firmware or the line!! never the way they have setup the box. it comes with experience its all the fun of it. it gets boring if everything is running 100% theres nothing to do then only watch tv .
                  • boylan
                    • Oct 2011
                    • 128
                    Yeah im a noob to all of this that is the result of my ping test thanks for the help by the way always nice to see someone helping others not just abusing them because they dont know :P
                    • sb18180
                      • Sep 2012
                      • 355
                      also always good to reboot satboxes,routers and modems regular (daily if possible) to remove any stale connections. also try connecting your satbox direct to modem if you have one and test quality then. also boyian you ping is not very good and you are getting packet loss maybe the cause? or its just talktalks crap service
                      • boylan
                        • Oct 2011
                        • 128
                        Hi i have went into my router settings and reset my router to factory settings and this seems to have sorted my problem, now my ping test is
                        Thank you for the help
                        • sb18180
                          • Sep 2012
                          • 355
                          thats a bit better
                          • boylan
                            • Oct 2011
                            • 128
                            Could it be better than that? whats yours round about?
                            • heigold2008
                              I was ok until Sly updated my hd box and now there is an extra number on my box serial number i have tried to sort this out with my server to no avail i get all channels except hd and movies think they have changed the boxkey system somebody will figure it out hopefully soon
