SkyBox F3 Help URGENT!
  • andrewfallan
    • Apr 2013
    • 6
    I got a new router today as old one is broke, I plugged it all in as normal and the SkyBox F3 is scrambled channels, it worked on old router fine.
    Youtube and You~~~~ apps are not working.
    Old router still works with the F3 but new one does not.
    AOL D-LINK DSL-2680.
    Please help me this is urgent?
  • sb18180
    • Sep 2012
    • 355
    are you getting internet connection from the router with other divices ie pcs? also is your satbox running from ethernet or wifi?
    • andrewfallan
      • Apr 2013
      • 6
      Yes I am using an ethernet from router to my pc, and a ethernet from router to skybox F3 and it is not working, ethernet works!
      • samsid
        • Mar 2013
        • 60
        Have you checked that dhcp in network settings on f3 is set to on?
        • sb18180
          • Sep 2012
          • 355
          yes make sure ethernet is activated on your box with green spot showing on ethernet tab and as above check dhcp is set to on.
          • andrewfallan
            • Apr 2013
            • 6
            Yes it is..
            • digicon
              • 8261
              What you should do is turn DHCP off reboot the receiver go back into the network settings and switch DHCP on and again reboot the box this way it clears the old IP address from the previous router and assigns you a new one from your current router
