please could somebody advise me i need a skybox but need advice on which one to pick i have looked at th f5 , blade 7000s and a few others please could someone advise on which would be the best? thanks
choosing a skybox
The best receiver will be whatever you can afford, a more expensive box is usually the better box.. Openbox/Skybox are budget receivers with limited features costing just 50 quid, a Blade 7000 is a much more capable receiver costing 150 quid...Comment
why not future proof yourself a bit and get yourself a tm5402hd,tm2600 motor trax td88 dish and inverto black ultra lnb, cable clips,t+k and pole all for under ?300 fit it yourself and get about 25 satellites. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Don't always go for latest or the most expensive ones, when choosing the main thing you have to look at is how much user support the box has this ensures that if you have problems then a solution has already been found by someone else, makes life so much easier.Comment
