hi all. just about to un-brick my skybox f5. skybox f5 currently shows a dim red light only visible once the black front panel is removed.
is the process below correct to unbrick skybox f5 satellite receiver.
1} connect pc serial rs232 port to skybox f5 using rs232 cable (from vu duo) while box is powered down.
2} Run EromUpgrade.exe selecting the correct com port (manage devices > ports - com1 applies to my computer)
3} Run the latest firmware (yogitech)
so under com settings
Port - COM1
Bits Rate - 115200
Parity - Even
Operate Mode - Upgrade
File - Latest firmware selected
Include Bootloader - ????
4} Select "next" then switch ON the box
and follow the instructions to load
and flash burn the firmware.
is the above process correct? Any input appreciated.
Regards.
Port - COM1
Bits Rate - 115200
Parity - Even
Regards.
