can't see 3d channel properly
  • dark5tar
    • Mar 2013
    • 26
    I see sky 3d channel in two frames , I have lg 65lm670t, when I click on 3d button on tv remote it merges both frames into one ,when I was using dreambox 800hd. But in F5 it doesn't do that, checked other normal youtube 3d clips they are fine, So I don't doubt TV. Is there any setting on F5 need to be done?
  • cactikid
    • 12017
    i would imagine there is a setting to change your viewing from 2d -3d and when finished you reset to 2d again.
    • brin251
      • 122
      wasnt aware this box had 3d capability
      • nibblitz
        • 1300
        The boxes dont have 3D capability, its the TV's that have the capability.... Openbox/Skybox can receive the 3D channels and the channels can be watched on a TV, but its the TV that has to render it as 3D, if the TV cant render 3D then all you will see is a split screen side by side mirrored picture.
        • mahrkpat
          • Jun 2012
          • 510
          All modern satellite receivers can do this but it is the t.v that converts the signal to 3D and don't get fooled by sellers trying to highlight the 3D capability and trying to charge you more for this.
          • cactikid
            • 12017
            did i not read he has a 3d button on tv remote?
            • nibblitz
              • 1300
              You did, he has a 3D button on his TV's remote, and I said its not the sat box that renders 3D, its his TV...... So basically, if 3D aint working on his TV then its an issue with his TV..
