SkyBox F5
  • bnz123
    • Apr 2013
    • 11
    SkyBox F5
    Hello people. Hope your all well.
    few quick questions
    1. I have 2 boxes in the house. These are connected through them homeplugs. If I was to turn the box off when not watching it, would this improve the signal on the other box or is there no point?
    2. Secondly in the antenna set up what is the transponder meant to be set to? Mine is (73/92) 12266 H 29500, is this the correct one? It's just certain channels like Comedy Central +1 say scrambled and was just wondering.
    thanks for reading and any help!
  • mahrkpat
    • Jun 2012
    • 510
    1. Shouldn't make a difference as long as both are on separate lnb feeds.
    2.The transponder will change when you change channels, if you got gift then try updating the channel list.
    • bnz123
      • Apr 2013
      • 11
      Thanks for the reply. Both boxes are connected to the same dish, plus there's two $ky HD boxes all in connected to that dish. And yes I do have that, any recommended channel lists?
      • mahrkpat
        • Jun 2012
        • 510
        I take it you have quad lnb and each box connecting to a separate feed.
        AJ's channel list is the one to get it is regularly updated.
        AJ's Channel List
        • bnz123
          • Apr 2013
          • 11
          Just successfully updated the channel list. Thanks for your help. Although a few channels are not working (scrambled), few channels which were not working previously are now so thanks for that.
          BTW does updating your channel list improve signal etc?
