Skybox F5/AJ Channel List Problems
  • afiqul
    • Apr 2013
    • 5
    Hi, just setting up a box for a friend and done a blind scan and installed AJ's channel list.
    Most of the channels work, but a lot of the HD channels are coming up with "No signal"
    Am I doing something wrong here? or is there a problem with the channel list?
    EDIT: I installed the channel list on my F3, and all the channels work...strange?
  • mahrkpat
    • Jun 2012
    • 510
    When you did blind scan did you see all the channels or were some missing? eg all hd channels missing or only some or also some sd channels missing as well?
    See this thread
    • afiqul
      • Apr 2013
      • 5
      I think some SD channels may have been missing aswell..
      I have the Satellite settings set up the same on both boxes. That thread makes it seem like an inherent problem with the F5's..
      Will try updating to latest firmware and see how it goes..
      • mahrkpat
        • Jun 2012
        • 510
        I don't think it is firmware problem for a solution See This Thread
        • afiqul
          • Apr 2013
          • 5
          hmm, I already have a quad LNB and running 2 lines down from the dish, one is in my own F3 and one is in my friend's F5 so i'm not sure exactly what is going on here...
          • afiqul
            • Apr 2013
            • 5
            Hmmm, I see this is a very common problem recently?
            Blind scan has both H and V channels found, with a few failures.
            The V channels gnerally only have a SNR of 7%.
            Anyway of fixing this? The other thread speaks of using a diseqc, but I don't understand how these would help..
