does any1 know how 2 change ip addys on the f5 i have 2 boxes gettin the fta channels when both r on together but not gettin the $ channels both boxes work on their own fine thanks.....gertie
f5 skybox
Tags: None
Hi, just realised it was ip addy you wanted to change, i thought it was the mac address
you can go into the network settings and select the wired network, there you can change it to dchp and the router selects ip addresses for stuff that connects,
i think you may find the reason your having the problem is because they are both connected to the same lnb though, my upstairs boxes 'f3 & f5' are on the same dish and i loose some (not all) channels if ever they are both on at the same timeIf it isn't broke, don't try fixin it..!!!
The 2 devices would be assigned different i.p addresses when dhcp is on what are you trying do have the devices have the same i.p addresses?
The problem you describe is has darcu5 said, that is having 2 devices on 1 lnb, in simple term whichever device is in control of the lnb will decide what you can watch on the device i.e whatever the transponder controlling device is on the 2nd device will only see channels on this transponder.Comment
got the problem sorted i had a twin lnb cable on 1 box i changed it 2 a single lnb cable now both boxes work perfect
