help copy files to usb root update
  • tuamsham
    • Feb 2011
    • 6
    hi folks have most of the work done i hope .have set up everything but in manage cccam.cfg it says need reboot can some one please tell me how i do that i have the littel box tick as well thanks folks
  • mahrkpat
    • Jun 2012
    • 510
    Reboot simply means switch your box off then on, either using your remote or the on/off button on box.
    • tuamsham
      • Feb 2011
      • 6
      thanks mahrkpat dont that now im in cccam client setup and it says copy files to usb root,update how do i do that thanks in advance
      • mahrkpat
        • Jun 2012
        • 510
        First format usb stick to FAT32 then put this in your box.
        Press menu on remote go to tool box select dump by usb select image.abs select start will get a drop down window select Cccam.cfg a tick should appear next to it then dump.
