I am not stupid when it comes to setting up the box but this time I am cattled. I am tryimg to set up wifi and have tested my Dlink wireless n usb mini adapter(dwa-140) on my laptop and it works perfectly but then the skybox won?t detect the stick when it is pluggedin,not even a light flashes on the stick,any ideas please.Is it the right usb and the box works ok with an Ethernet connection.....Ricky
Skybox F5 HD wifi..
Tags: None
The F5 is not very good with wifi but try this:
1.Make sure dhcp is set to on in network settings on your F5.
2.On your router set the channel to something less than 6 if it is on a higher setting or on auto.
3.Reboot F5, reboot router
If this doesn't work and Ethernet cable not a option invest in home plugs.
