Comedy central and e channels not working???
  • singh1234
    • Aug 2009
    • 156
    my comedy central works but +1,xtra comes up glitching and unwatchable,also my e entertainment channel just does not work at all says scrambled. please help.
  • darcu5
    • Jun 2011
    • 944
    Have you checked the signal strength and gone to kingofsat.net to check the tp's make sure you have the right ones.
    • singh1234
      • Aug 2009
      • 156
      signal strength is about 75 then keeps going down to about 40s,its only these channels am having problem with
        dont take a blind bit of notice of the signal strengh meter on the Openbox/Skybox range i have seen plenty that do not register below 73 and also do not go above 75 even if the signal level is actually more along the lines of around 35% snr, probably due to the firmware and a bug that has never been fixed although i have seen the odd one that will register about 86% but the majority stay around the 73-75 mark
        the E Channel and the CC+1 ae located on Eutelsat 28A satellite which out of them all co-located at 28 east is the weakest of them all which may indicate an alignment problem something you wont find out unless you plug a pro-meter into the dish and get a true reading
        • singh1234
          • Aug 2009
          • 156
          they was working fine but all sudden e channel is completely off for last few weeks and cc1 is blurry and fuzzy
