Looking for a quad lnb new dish
  • singh1234
    • Aug 2009
    • 156
    I currently have a single output sky dish the old ones, I am looking to get sky also connected in another room, what do I have to do,do I buy new dish or what????
  • DW190
    • May 2012
    • 1263
    You'll get one off fleabay for under ?20.00 delivered or if you have a friendly $ly installer sat in his van locally you may even get one installed for about ?40.00.
    • singh1234
      • Aug 2009
      • 156
      I can get a dish quad lnb for 15 local, can I just get any dish? is ity easy to fix up and wud it mess up my skybox?
      • DW190
        • May 2012
        • 1263
        You can just swap the lnb which will cost about ?6.00 and buy some twin sat cable with a few f ends.
        quad lnb | eBay
        • Hadron
          • Nov 2012
          • 2102
          The latest S l y LNB's (Mk4) fit over the arm of the dish. The older dishes had an LNB that fitted inside the dish arm.
          If your dish is of the second, older type then a MK4 LNB will not fit without an adapter.
          • singh1234
            • Aug 2009
            • 156
            so is it best to buy a new dish then??? is it easy and wud it make any difference to my skybox?
            • mahrkpat
              • Jun 2012
              • 510
              With the way things are going read this you wouldn't go wrong by installing a motorised dish but if you don't want to this a lot of LNB are supplied with the adapter therefore no real need to change dish.
              • singh1234
                • Aug 2009
                • 156
                so can I just buy a lnb then instead of change of dish?
                • mahrkpat
                  • Jun 2012
                  • 510
                  Yes you can but remember for extra stb's you will need cable and F connectors also for any stb that has twin tuners will require 2 cables.
                  • singh1234
                    • Aug 2009
                    • 156
                    what is a stb? yeh I will get a new quad lnb a new cable and connector,is that all I need cuz all I want to do is have another sky box in other room??? what twin tuners, I have one skybox in 1 room and want normal sky box in other room??
                    • mahrkpat
                      • Jun 2012
                      • 510
                      Sorry sometimes one forgets and uses techno speak stb=set top box=skybox.
                      • singh1234
                        • Aug 2009
                        • 156
                        thanks,wats a twin tuner box mate u say?i have been told I can get a new quad lnb maybe to put on my old dish as it is over 10yrs old and then put another cable to other room,can I do that is it easy to do?
                        • mahrkpat
                          • Jun 2012
                          • 510
                          The cabling depends what obstructions are in the way an how far away it is, if you are not confident get it done professionally.
                          By having 2 tuners in one box allows you to record one program while watching another, Sky + boxes are twin tuner, the F3 isn't but in the future you might like to get a box that has twin tuners.
