it says no file found when i try to put CCcam.cfg on my skybox f5 its my first time
  • davidthe
    • May 2013
  • smoggy
    • Apr 2009
    • 12774
    have you put the file on to the root directory of your USB stick as Cccam.cfg
    • mahrkpat
      • Jun 2012
      • 510
      Not trying to under estimate the user or give any offence but by root directory means not in a folder just the file Cccam.cfg.
      Good luck.
      • leon632
        • 129
        You can enter it manually. Press 6666 on menu page for extra option on menu I think
        Sent from my GT-N7000 using Tapatalk
        • slugworth
          • Nov 2011
          • 1064
          receiver save to usb,edit that file and save so you know the file is named correctly and in the correct location.
          • mahrkpat
            • Jun 2012
            • 510
            It is very easy to create using notepad on your pc: just open notepad then put the line in and then the save as option and in the file type option select all file types.
            • badboy1965
              • 191
              it only goes in like this (CCcam.cfg) using note pad and don't forget to save it as ALL FILES.
              • darksky
                • 7
                I had the same problem and eventually found that the C .... and F .... must begin with an uppercase C: or F: for the box to read it.
