OpenBox S6000HD
  • jmegordon
    • May 2013
    OpenBox S6000HD
    Hi, I'm looking for peoples opinion on the OpenBox S60000HD box. I will post in the relevant section this is just a brief introduction as to what my first post will entail. Thanks
  • ajax2061
    • Nov 2012
    • 395
    seams to be loads asking about them but no one saying they got one, they seam to work as a vu clone and if so are a dam cheap option
    • mahrkpat
      • Jun 2012
      • 510
      You might be interested in this thread any-one-heard-openbox-s6000hd
      • dial1971
        • May 2013
        got one coming in next two days will post back asap ive it got set up and working look the bollocks for the money though
        • lincsat
          • 1228
          They are basically a copy of the Vu+ solo in a plain black box, they are slightly smaller than a DM500. I've been supplying them with an OpenPLi image installed but they can take Blackhole 2.0.2.E OK. Note: There is a SD card slot but there is no reader, so don't try to insert one.
          • dial1971
            • May 2013
            for the money they are great im only just getting use to the hole enigma / linux/ blackhole etc way of working as ive only ever worked with f3/f5 type of box but as a stater for the money these are great just make sure if your going to use timeshift and full 7 day epg you put a external hdd or decent size mem stick in it and no they do not over heat so shop round try lincsat he gives great back up if your having problems
            • dvbfreeview
              • Mar 2013
              • 23
              Openbox S6000HD working good with blackhole Enigam2 , but cheaper than Dreambox800HD.
              • dvbfreeview
                • Mar 2013
                • 23
                Openbox S6000HD can use the third part firmware, such as blackhole, OpenVix, OpenPli.
                • bubaloey
                  • Jun 2013
                  • 4
                  looking to enter info in cccam.cfg on openbox s6000hd but not seing where to put the info, using openpli
                  • DW190
                    • May 2012
                    • 1263
                    I think its var/keys
                    • samsid
                      • Mar 2013
                      • 60
                      for CCcam it's var/etc/ for MGcam it's usr/keys/
                      • lincsat
                        • 1228
                        For CCcam its /etc/ for MGcam it's /var/keys/
                        • egibbons
                          • Sep 2009
                          • 59
                          Is there a guide to fit cooling fan please
                          • andy91
                            • Aug 2010
                            • 3583
                            Better to buy one of those cheap fans that run off usb and plug it straight in, think you can buy them from pound shop Andy.
                            • adetheprince
                              • 6
                              The best version is the one you get with the fan installed and its very quite unlick the 800se.
                              I have bought mine from satellitedoctor.co.uk , there have all the one with fan installed , carefull not to buy the one without fan as it get very hot.
