Hi I'm trying to set up my Skybox F5 but I don't know what Satellite I need on the list thing as there is loads and when I scan I keep getting Non-English channels. How can I just get the Sky UK Channels? Do I need to put any firmware on the box or anything?
Skybox F5 help!
See this post here the search function is a wonderful tool to use: http://www.digital-kaos.co.uk/forums...ml#post1959720
Hi Thanks I have downloaded this and put it onto a USB but then When I update via USB after it says done I don't see nothing?See this post here the search function is a wonderful tool to use: http://www.digital-kaos.co.uk/forums...ml#post1959720Comment
When you select upgrade by usb option you must < > on your remote until you see Misc file.
The tp_prog.dbs file must be in the root of your usb stick i.e not in a folder, you are in wrong menu if you are seeing keep dbs and setting probably upgrade firmware do not press upgrade here unless you want to upgrade firmware.Comment
Hi thanks for your help I figured it out now but I got a problem. I can see all of the channels but it just says no signal on all of them? What do I need to do? Sorry but I'm really new to this as you can probably tell.When you select upgrade by usb option you must < > on your remote until you see Misc file.
The tp_prog.dbs file must be in the root of your usb stick i.e not in a folder, you are in wrong menu if you are seeing keep dbs and setting probably upgrade firmware do not press upgrade here unless you want to upgrade firmware.Last edited by Chael; 12 May, 2013, 18:07.Comment
which brings me to the question which is: what satellite is your dish pointing to, the reason i ask is that most Openbox/skybox owners buy these things for use on a Fixed dish aimed at 28.2? east
Ok the channels I was able to watch were: Music Al-Haneen, Pentagon Channel, Angel TV, Program-11, Program-9, anta oana obs, NLM TV, DIVINE TV, Duna, Duna World. All then channels worked but then when I put the Channel List on there not even BB1, or ITV1 would work.Comment
well atleast I know what the problem is now and thank you for telling me. This means I'm going to have to go back up there and how will I know when it is pointing at 28.2 east?
