F5 Installation menu options no longer available
  • dekmac2000
    • Apr 2013
    • 5
    Hi
    First post on this forum so all help appreciated
    Got an F5 box a few weeks back and after reading various posts on this forum got it all up and running.
    Went to conduct a blind scan to refresh the frequencies today but the only options that are available to me from the Installation menu are Installation antenna , Satellite list and LNB power
    The following options are "greyed out" Antenna set up , single satellite search , multiple satellite search and TP list
    All functions and channels work
    Is there a code I can input on the remoter control that enable the 4 options currently disabled.
    IS there something I can do to enable the 4 missing options
    Thanks for reading
  • genam
    • Apr 2013
    • 176
    my code was just 0000
    • dekmac2000
      • Apr 2013
      • 5
      genam , thanks fo rthe quick reply
      I tried 0000 , 1111 , 2222 , 3333 , 4444 all the way up to 9999 but none of them work
        Its probably due to the fact that you have it setup for a single satellite only which renders the other options useless
        • dekmac2000
          • Apr 2013
          • 5
          digicon , thankyou for the feedback
          I have an F3 box is another room set up as single satellite and this has all the options within the installation menu enabled
          • samsid
            • Mar 2013
            • 60
            if you check Satellite List you'll find the problem lies there, if there's nothing there this will 'grey out' the options you mention
            • Hadron
              • 2102
              Hi
              Thanks for reading
              This happens if you don't have a "tick" next to the details in the Satellite list.
              In the Satellite list menu, press the "OK" button to place a tick next to the details. When you exit, the other options should be available.
              • dekmac2000
                • Apr 2013
                • 5
                Hadron
                Thankyou for your reply. Did what you have said and all options now back and available
                Thanks for your help
                • jckw
                  • 760
                  f5 messed up
                  Hadron
                  u have a f5 but was not getting espn or various other channels done a tp scan it never work and done a satalite scan now there is no signal on all channels what have i done
                  we are all learning each day
                  • dekmac2000
                    • Apr 2013
                    • 5
                    jckw
                    I have found the same issues sometimes. Power off the f5 box via the remote control , turn back on via the remote control and in my experience the channels come back
                    Hope this helps
                    dekmac2000
                    • jckw
                      • 760
                      thanks i tried this but no luck i think i have change what satalite somehow
