can't get racing uk on f5
  • mark080270
    • Oct 2008
    • 36
    hi all bit of help if possible just got an f5 for my dad but can't get racing uk on it so I have an f3 so used the tp list I have on my box which I get racing uk but no luck so I searched the channel 11584 but still no luck when I go into sports and go on the channel it just says invalid program search again I have never had this on mine please help thx in advance
  • samsid
    • Mar 2013
    • 60
    Racing UK is now on 11527 /27500/ v
    • jonnyhomes
      • 54
      The new details are
      FREQ 11527
      Symbol rate 27500
      Polarity v
      To add theses go to TP list in installation menupress green button
      add values then save.You'll be taken to new transponder listing press blue search key and when you're done channel will return
      hope it helps
      Cut and pasted from another forum .. so thanks to the OP ..
      • DL1982
        • Sep 2012
        • 104
        Will this method also work on the openbox s11 as my racing uk has also knocked off
        • mjhwr
          Hi. did a manual search on new frequencies o my dreambox 800hd and RUK came up on transponder list but screen is still black, any help would be much appreciated. Thanking You
            You wont get any help on the matter with the screen is black problem please read the Forum Rules:
            • Hadron
              • 2102
              Yep.
              You will probably find that the required TP is already in the list, as it is already used by Motors TV & Man U TV, so no need to add it first. It may be shown as 11526.
              • phunkmonk
                • Jan 2013
                • 4
                Ive tried using this method, saved all the settings and currently using AJ's channel list
                However after saving the details, and also rescanning i can't get it to work
                is there any way that i can manually set up a channel?
                • bubble1066
                  • 12
                  attached file has racing uk on
                  [ATTACH]199795
                  please use this as it is upto date as of today
                  extract file from winrar file and place on usb
                  press menu
                  goto tools
                  select upgrade by usb
                  change image file to misc files and select and upgrade
                  tick tpprog.dbs and press yellow
                  now reboot
                  • verysweetdeals2
                    • 11
                    your file is corrupt cheers
                      The File that bubble1066 uploaded is fine i just tested myself
                      • bucharoo
                        • Dec 2012
                        • 20
                        Will this TP work on eyebox x3 as I have same problem RUK classic movis all gone?
