Skybox F5 Hz Rate
  • cactikid
    • 12017
    #16
    thinking years ago when i was buying a panny i had an option of a 50hz tv or a 100hz,looking at the 50hz the picture was not as sharp as the 100hz and that was on scart,is his tv below par with todays ratings,worth a try on another tv?
    • road
      • May 2013
      • 16
      #17
      Hi @cactikid i did try with scart but too bad than hdmi.. when i used does not give like hdmi.. giving 576i with scart(rgb).. it does not give 1080i yuv line i give up this option .. but i did not try on another tv because i don't have another one i will wait an update for f5 thanks for comments regards
      • road
        • May 2013
        • 16
        #18
        someone can say skybox company need 30hz or 25hz setting for video options maybe they can work on it just like openbox x5 ... you can see options on x5 thanks
        • mahrkpat
          • Jun 2012
          • 510
          #19
          I know you are concentrating on the 30hz / 25hz option but please like someone suggested in a earlier post, change your hdmi cable, doesn't have to be expensive gold plated one a cheap one will do, I am asking you to do this because no one else has reported a problem like you are having and once you have tried this let us know if it made a difference.
          • road
            • May 2013
            • 16
            #20
            you know there is a hdmi cable in box i don't use it because not gold and try it still same i am using philips gold hdmi again same i am not sure what is reason i updated tv firmware a few ago 40c530 it is 2011 date maybe that is why i want to back old tv firmware now i can't find it ... i am very sad for this problem .. i jut thinking i should use 30hz setting but no option oohhh goddd thanks mate
