help please
  • bob909
    • May 2013
    • 8
    help please
    I have just setup my skybox f4 with a motorised 100cm dish. My problem is i am new to all this satellite stuff so be nice, I can not receive any uk channels FTA i did a blind scan on the Astra 1H/1K/1L and Astra 1c and get thousands of non uk channels some in HD. There is no ASTRA 1N | ASTRA 2A | ASTRA 2B | ASTRA 2D | ASTRA 2F in my channel list to do a scan. What am i doing wrong. Satellite setup in L20 post code.
  • Hadron
    • Nov 2012
    • 2102
    Your channel list should also show their positions, as well as their names, so choose whatever name corresponds to 28.2e.
    If there isn't one, you can always manually add it yourself.
    • bob909
      • May 2013
      • 8
      Thanks for replying .How do you manually add.
      • bob909
        • May 2013
        • 8
        well i have truly done it now. I did a factory reset and now all my preloaded files have gone can some one help me set up my box please. I need to install all the missing camds for my skybox f4 software version 3601HD _18082012_046B
        • DW190
          • May 2012
          • 1263
          When in the network menu press 6666 on the remote.
          • Hadron
            • Nov 2012
            • 2102
            Looks like I am too late now, but for future reference if you want to add a satellite:-
            Menu > installation > satellite list. Press green button to add. Give the satellite a name, then type in the longitude (028.2 E for S l y UK). Press OK. Press OK again to put a tick next to it.
            Press exit to go back to the installation menu. Select Antenna setup. Select the satellite you have just entered with the left/right arrow buttons. Set LNB Freq to Universal (9750 - 10600). Set DiSEqC 1.0 & 1.1 to disable. Set 22k to on. Set your motor type.
            Press exit to go back to installation menu. Select single satellite search. Select the satellite & do a blind scan.
            • mahrkpat
              • Jun 2012
              • 510
              You can try this old multisat channel list it will give you a starting point afterwards you can update the tp's, remember to align your dish to a known satellite first then use usals.
              multisat list.zip
