If i get a 2 into 1 USB cable can my Skybox F5 handle a wifi ariel and a USB memory stick at the same time?
USB doubled
Tags: None
I tried this a few weeks ago with a USB hub..powered from the USB itself and only recognised 1 device at a time...but not convinced it was the F5 at fault as the Hub didn't run the external hard drives i have that work fine when connected directly to the F5...maybe an externally powered Hub would have better luckComment
I advise you that the F5 can only recognise one device on the usb port but you think it is the fault of the usb hub easy enough to test by connecting the hub to your pc and see jow many device you can connect now.I tried this a few weeks ago with a USB hub..powered from the USB itself and only recognised 1 device at a time...but not convinced it was the F5 at fault as the Hub didn't run the external hard drives i have that work fine when connected directly to the F5...maybe an externally powered Hub would have better luckComment
