HELP SKYBOX F3!!!
  • jimmyk68
    • May 2013
    • 8
    HELP SKYBOX F3!!!
    hi, i upgraded my skybox f3, prob is ive lost all the sky channels ( just showing scrambled) im not sure if ive lost my @gift@ from the original vendor. anyone know how i can get these back? i used aj,s list, and all my channels are now in order but i cant view them, any suggestions?? thank you
  • seangraves
    • Sep 2012
    • 275
    pm you mate ,,,,
    • samsid
      • Mar 2013
      • 60
      Before you do anything in menu ,go to Network Local Settings,then Network Setting & check that DHCP is set to on.Most newer firmwares don't remove your 'unmentionable,however some variants of the latest firmware release set DHCP to OFF which will result in what your experiencing now.
      • ajax2061
        • 395
        if you didnt delete your existing channel list 1st it could be this delete list and reinstall, but before you do anything you should always do a backup
        • P&D
          • 2686
          Hi sorry this is a taboo subject
          try here to find out Google how to get your channels back
          You may want to read line 6 here http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/
          Try .....
          Menu
          camd setup
          manage files
          make sure there is a green tick next to you know what
          reboot & see how you go
          if the you know what is not in there you have lost ti
          • jimmyk68
            • May 2013
            • 8
            Try .....
            Menu
            camd setup
            manage files
            thanks for your help, much appreciated, read line 6, got it now, . cheers
            • xlsteve
              • 5
              I have same problem,,can you pm me,thanks
              • P&D
                • 2686
                Hi Steve
                what problem are you having ???
                have you ever had the channels ??
                Plz explain what probs then peeps might be able to help
