skybox F5 help please
  • scouse08
    • 17
    would just to say i dont know if am posting in the correct section or posting something i should not ask - sorry if i am
    buyin a skybox f5 ..which software do i need ? i have seen the openbox info and not sure if there the same i need can some one point me
    to the correct files i need thanks again !!
  • digicon
    • 8261
    And what exactly is it you want to do with the F5 when you purchase it, Just a Hint here but anything to do with The so called 'Gift' functionality is a no Go area to be discussed on here anything to do with the firmware and channels is fine
    • scouse08
      • 17
      firmware and channels ..i know you can buy the gift via ebay ..is that what you mean ? am new to all this skybox f5 ...
      • digicon
        • 8261
        Firmware can be found here: SkyBox | SkyBox
        Probably the Best Channel List and most Popular and always updates has to be AJ's : http://www.digital-kaos.co.uk/forums...ml#post1981894
        • road
          • May 2013
          • 16
          skybox f5 not bad a box but if you want to buy it.. you don't want to buy china seller because they don't care after selling a box no warranty no answer you don't want this i am warning all .. there is no any warranty with the china seller.. stay away from china sellers.. stay away from china sellers thanks regards
          • mahrkpat
            • Jun 2012
            • 510
            The F5 is a newer model than the F3 but read the forum it has lots of different hardware problem eg dodgy psu, misaligned i.f sensor, sometimes either the Ethenet port or wifi not working. I would go for the F3 you would get all the functions that the F5 has because they use the same firmware.
            • scouse08
              • 17
              the f3 as no hdmi on that model where the f5 as !!
              • mahrkpat
                • Jun 2012
                • 510
                Have a look at this it is the back of the F3 you can see it has hdmi output:20120330162633840.jpg
                You can see the full spec here: skybox F3 specs
                • scouse08
                  • 17
                  yeah just seen getin one on monday or tuesday ..as there out of stock
                  • yellowking
                    • Feb 2010
                    • 18
                    The M3 is even better smaller and no inbuilt PSU to go wrong.
