F5 - Box Nation Problem
This topic is closed.
  • Geoff1986
    • Jun 2013
    • 9
    I just keep getting scrambled on this.
    I am on the latest update of Aj's channel list. I have emailed my gift supplier and he seems to think it should be working if I do a rescan as the channel D809 is the problem.
    Even when I tried that it doesn't work and he has told me from my log file that I haven't tried to open 'Box Nation' when according to my box I am on that channel.
    Any help would be much appreciated.
  • P&D
    • May 2010
    • 2686
    Hi check your channels that say NO NAME it will be one of them
    • Panther785
      • Aug 2012
      • 79
      sky has changed a lot of frequency this week u will need to add a the new one check out king of sat or flysat
      • Geoff1986
        • Jun 2013
        • 9
        I will have a look at those, thanks.
        From a bit of Googling it shows that the one I have apparently got is on the right freq.
        • kingfisher1971
          • Dec 2010
          • 12
          am struggling with this as well done full channel scan still no joy
          • Geoff1986
            • Jun 2013
            • 9
            Update on this.
            I updated my channel list again and I got Box Nation on although it only lasted about a minute on 2 occasions before being scrambled again.
            Doing my head in as I wanted to watch the Broner fight last night.
            • jelli6
              • Mar 2013
              I had the same prob..on freq 11585 with my F5. eventually found 2 other boxnation entries, both work and are in the all satellite list, one is on channel 1011 freq 12607, although i haven't worked out how to replace the boxnation entry in my sky uk list .
              • Geoff1986
                • Jun 2013
                • 9
                This one I have got now is freq 12607
                • Geoff1986
                  • Jun 2013
                  • 9
                  Found a weird temporary fix to this if you just want to watch Box Nation for an event.
                  If I delete all my channels and then re up my list and go to Box Nation then it works, if I turn over for a while and try to go back it is scrambled again.
                  Doing my head in all this though.
                  • MickSmart
                    • May 2013
                    • 27
                    You need to delete the old box nation out of your channel list and simply add the new one and save it ....
                    The quickest way to edit your abs/channel list is using something like "SetEditHD100" its like dreambox edit for the openbox range, much faster than using the box menu and moving channels with the favorites option.
                    • Geoff1986
                      • Jun 2013
                      • 9
                      I've deleted Box Nation then re searched the TP and tried the new one found.
                      Same result.
                      • mdt
                        • 3034
                        its a clash at your providers end.... your box gets confused,regards mdt
                        • Geoff1986
                          • Jun 2013
                          • 9
                          What does this mean?
                          I can get it to work intermittently
                          • digicon
                            • 8261
                            It means that your Box is receiving the satellite signal and everything on that part is just fine the rest delves into a Grey area which cannot be discussed on this forum, I know exactly what mdt means and i can tell you now its a problem with something else entirely, I suggest you get back on to your person who supplys your 'Special Access' and ask him as i stated nothing wrong with the channel list or signal so this subject is closed
