can noy update my skybox f5
  • ahmedsaleh
    • May 2013
    hi evey one
    i am sure it is very easy to you why in f5 the dump by usb not highlight so i can not use it for update list or backup
  • P&D
    • 2686
    Hi silly question but have you put the usb flash pen in the back of the box ????
    if yes then it sounds like the usb port is ****ed
    • mtv1
      The Stig PT
      • 4413
      is the usb stick in the box ??
      • ahmedsaleh
        • May 2013
        i did with the new update
        • P&D
          • 2686
          Sounds like the usb slot is goosed
          • mtv1
            The Stig PT
            • 4413
            can be easily replaced but if the box is new contact your supplier good luck mate
            • DW190
              • May 2012
              • 1263
              I have noticed lately that the USB slot switces off if you have it in when you switch on. After uploading software on reboot the USB is usually off again and requires removing and replacing.
              When your in the tools screen put your USB stick into the unit, make sure its push fully home and see if the USB options highlight.
