Openbox s11 tuner boared
  • redralph
    • 171
    Is anyone aware were I can purchase a tuner board for the Openbox S11, that's the one with all the caps. on.
    Its quite easy to get the power board but its the tuner board I require. Thanks in advance
  • DW190
    • May 2012
    • 1263
    Original Sharp S7VZ7306A Tuner Standing Type 7306A for openbox skybox S9 S11 F3 F4 X3 X5 satellite receiver free shipping-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com
    • redralph
      • 171
      Thanks but they only sell the tuner for the S11 not the board with all the caps on
      • slugworth
        • Nov 2011
        • 1064
        the bookmark link I had for the tuner module is dead.
        I think it was around $11 at the time
        • DW190
          • May 2012
          • 1263
          Here's the full one but out of stock by the looks:
          Wholesale Original Sharp Tuner board for openbox s10 skybox s10 tuner satellite receiver post, Free shipping, $10.97~14.82/Piece | DHgate
          Here you go:
          http://www.ebay.co.uk/itm/Openbox-S1...item3382bc1659
          • redralph
            • 171
            Thanks again but that board is for the S10, the S11 is different, it as a vertical tuner. Strange how the S10 is available but not the S11.2013-06-24-233.jpg
            • slugworth
              • Nov 2011
              • 1064
              probably cheaper just to buy an old receiver at this stage of the game.
              • Hadron
                • 2102
                That's because, as your photo shows, the S11 doesn't have a separate tuner board. It's incorporated into the main board.
                As slugworth says, it's probably easier & cheaper to buy another S11.
                What problems are you having?
                If it's a no signal problem, have you checked F1 (the toffee coloured component near the tuner box)?
                • redralph
                  • 171
                  The box just died, perfect one minute dead the next. Thought it might be one of the caps. If you look at the photo, its the one to the right of the tuner, it looks as if something is leaking from the top, but i'm no expert so I was going to change the whole board, I'm no good at soldering anyway.
                  • DW190
                    • May 2012
                    • 1263
                    If the box just died that is more likely the Power Supply Board rather than the tuner.
                    • Hadron
                      • 2102
                      Don't think it's a leaking cap. Looks more like some sort of glue. You can see it on other parts of the board.
                      As DW190 says, it's more likely to be the PSU board. What do the caps look like on that board?
                      It may also be a corrupt firmware. Have you tried reflashing using the RS232 serial method?
                      • slugworth
                        • Nov 2011
                        • 1064
                        I don't know about the s11 but if the s10 tuner has a loose connection to the mainboard the receiver will kick into clone detect mode and die.
                        I had that happen to a genuine s10,the tuner is part of the id circuit.With the tuner out the sys info screen shows all zeroes for the id's
                        • redralph
                          • 171
                          Sorted just a cap that had blown. Local guy repaired it. Thank you for all the advice.
