Skybox F3 Component Video Output
  • Rinty69
    • Jun 2026
    I'm looking at either an F3 or an F5, and I'm leaning towards the F3 because my TV only has no spare HDMI input, but it does have a component in.
    I've seen mixed comments about the component O/P on the F3, so is anyone using it? Am I better going for an HDMI to component converter in which case is the F5 a better buy?
    TIA
    Have you not thought about an HDMI splitter preferably a powered one these are available in 2/3/4 outlets
    • Rinty69
      If it's an easier/better option then yes, but I hadn't thought about it TBH.
      • ajax2061
        • 395
        I use a 3 way switch cost about 4-5 quid from ebay, got pc appletv and skybox plugged in. When I want to switch I just press button on switch an hey presto I am on the other device, heck with the pc it auto swaps from monitor to pc where as before I had to tell the pc to use the telly, makes games on the big screen easier
        • Rinty69
          Yeah, I've decided to go for a switch - it's by far the best option.
          This one looks okay.
          • Hadron
            • 2102
            There are cheaper ones on Ebay. Haven't tried them myself yet, but I might try these 2. 1 is manual & the other remote controlled:-
            New HDMI 3 Input Switch Hub Switcher Splitter Box Port for HDTV 1080p UK Stock | eBay
            Auto IR Remote HDMI 3 Input Switch Hub Switcher Box Port for HDTV 1080p | eBay
            Bear in mind that these unpowered HDMI switch boxes don't always work correctly, particularly with Sly+ boxes. As digicon says, it may be worth getting a powered one, depending on what equipment you need to switch.
