I've found lots of comments about looping the LNB signal, saying both you can and can't do it, which have left me a little unsure about this. It will probably only be a temporary setup until I get another cable in place, but I want to keep the dual LNB feed to the Sky+ box and sit the Skybox on top and loop one of the LNB feeds through it to the Sky+ box.
I know both can't be used at the same time, so will that cause any problems? What happens if the Sky+ box is recording and I turn the Skybox on? Any risk of voltage damage to either box, etc?
Cheers.
Cheers.
