What is the best router I can use for skybox f5? Or is there a tut to change settings on your router? I currently have sky broadband router
best router to use?
Tags: None
The term urinating on your own doorstep springs to mind but thats up to your self, You cannot change the router when you signed into the agreement you also signed into using $ly's own equipment and they dont make it easy to retrieve the User and pass you need to use a 3rd party router, if you do get the info and use another one expect to have your service cut
They won't cut your service if you're using a 3rd party router, i've been using an asus one i purchased for over 6 months, as long as you inform them before setting the router up with the details you retrieve through 3rd party programs then it's fine and you waive your right to technical support should a problem arise
source - ex support for skyComment
Good point about the doorstep, u can tell im a newb! If i split the phone line and use a different router will that work? Or is the line still sly's?The term urinating on your own doorstep springs to mind but thats up to your self, You cannot change the router when you signed into the agreement you also signed into using $ly's own equipment and they dont make it easy to retrieve the User and pass you need to use a 3rd party router, if you do get the info and use another one expect to have your service cutComment
thanks for help
