Moved Frequency Channels Updates 07/06/2014
SyFy HD (Channel 114) Changed frequency to 12.382 H 29500
Sky Channel 995 has now been removed from Sky EPG 995
Nick Jr Peppa (Channel 620) relabelled back to Nick Jr 2
Thane Direct (Channel 660) relabelled as Thane
Active channel (Channel 281) Changed to EPG Position 449
Flirt TV (Channel 938) removed as left Astra 28a
ITV Encore HD (NEW Channel) Channel 123 (10832 H 22000)
ITV Encore (NEW Channel) Channel 298 (10891 H 22000)
ITV Encore +1 (NEW Channel) Channel 193 (10906 V 22000)
21st cent Bliss (Channel 376) rebranded Bliss
Dirty Talk (Channel 935) removed as left Astra 28a
Sky Sports 5 (TESTING) (Channel 1077) 11914 H 27500 (Blank Screen at present time)
Forces TV (TESTING) (Channel 1078) 12552 V 22000
The Following HD Channels have been replaced with the SD alternative Higher up the EPG
Sky 1 HD
Sky living HD
Sky Atlantic HD
History HD
Crime HD
National Geographic UK HD
Nat Geo Wild HD
Sky Arts 1 HD
Sky Arts 2 HD
Sky Premier HD
Sky Showcase HD
Sky Greats HD
Sky Sci Fi / Horror HD
Sky Disney HD
Sky Family HD
Sky Drama HD
Sky Thriller HD
Sky Select HD
Sky Sports 4 HD
Sky Action HD
Sky Comedy HD
FAQ's
Can anybody tell me the difference between the 4 channel lists uploaded, I am not sure which
one i need ?
Full HD:
BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the HD Versions
the SD Versions are at BBC 1 SD 141, BBC 2 SD 142, ITV1 SD 178, Channel 4 SD 230, Channel 5 SD 171
Full HD No Adult:
Exactly The same as Full HD except all adult channels have been removed
Sky HD:
BBC1, BBC2,ITV1,Channel 4,Channel 5 at channels 101-105 are the SD Versions
the HD Versions are at BBC 1 HD 141, BBC 2 HD 142, ITV1 HD 178, Channel 4 HD 230, Channel 5 HD 171
Sky HD No Adult:
Exactly The same as Sky HD except all adult channels have been removed
When wanting to type in a channel e.g 101 or 401 why do i get "no such channel" ??
Press the ok button, then press the red button then select All.
Then when you come out of that press 101 or 401 and hey presto you should then get the full list of channels.
What boxes will this list work on ?
The Channel List is suitable for Openbox/Skybox S9, S10, S11, S12, M3, X3,F3, F3s F4, F5 & F5s
My Favourites are all wrong since I loaded your list how do i fix them ?
The way to get The favourites under the correct headings is to load the default Database:
On the remote select Menu > Factory Settings > Select Yes > Then Press Blue (Don't make any choices at the menu)
The screen will flash black and you will be back at the menu. If you check your favourites now they should all be in the correct order
Your channel list hasn't installed when I press info there was a comment like " file not found" or something similar ?
Try The following:
Check you have unzipped the channel list from the zip file
Make sure that TP_Prog.dbs is on the root of your flash drive
Redownload the list using a different web browser
What's the favourites.jpg for in the zip file ?
It's just to show you what your favourites list on your box should be labelled like
Sky 1 HD
Sky living HD
Sky Atlantic HD
History HD
Crime HD
Nat Geo Wild HD
Sky Arts 1 HD
Sky Arts 2 HD
Sky Premier HD
Sky Showcase HD
Sky Greats HD
Sky Disney HD
Sky Family HD
Sky Drama HD
Sky Thriller HD
Sky Select HD
Sky Sports 4 HD
Sky Action HD
Sky Comedy HD
FAQ's
one i need ?
Full HD:
Full HD No Adult:
Sky HD:
Sky HD No Adult:
Try The following:
and a lot easier to answer questions and see feedback
