Vonets wifi bridge on skybox f3
  • beechams
    • Apr 2013
    • 21
    How do I get it to work? If it doesn't can someone recommend a good one because my last one kept cutting out. One for around 20 pounds would be fine.
    Anyway I got a vonets wifi bridge vap11g for my skybox f3 and I can't get it to wwork could someone tell me how with literally baby instructions in case I missed something and btw if I have a ip such as 122.122.0.1 on the skybox f3 is that 122.122.000.001 or something else? Any help is appreciated, tthanks my router is a virgin super hub 2 if that makes a difference
    thnks
    oh and I got the vonets working on my laptop but when I plug it into my skybox f3 nothing happens and my channels are still scrambled
  • samsid
    • Mar 2013
    • 60
    in short the Vonets won't work properly if at all with skybox. Try and get a refund ,get some homeplugs and you'll be fine
    • DW190
      • May 2012
      • 1263
      thnks
      As long as its working on your laptop, it should work on your F3. The F3 should be set to wired connection for a Vonets using the USB to from the box to power it.
      • beechams
        • Apr 2013
        • 21
        Why? And can you reccomend a good home plug?
        • beechams
          • Apr 2013
          • 21
          I did that and it didnt work, also does it have to be powered via the box? I plugged into the wall via a USB plug
          • DW190
            • May 2012
            • 1263
            USB mains adaptor should be ok.
            Is your DHCP set to ON
            Is your Network set to Wired
            Homeplugs can be a bit pricey, I use them without any problems and daughghter uses Vonets.
            If you want a reasonably pried Homeplug set look here:
            ON NETWORKS PL200-199UKS 200 Mbps Powerline Adapter Kit Deals | Pcworld
